scrammy 4x4
Old Apr 1, 2004 | 10:55 PM
iwannabfast's Avatar
Default scrammy 4x4
i have a 95 scrammy 4x4 only the right front tire spins in 4 wheel drive any solutions?
also is it possible to remove the halfshafts if i want to take off the 4x4 what else do i have to take off (besides the center chain)
Old Apr 1, 2004 | 11:02 PM
RAJ's Avatar
RAJ
Default scrammy 4x4
Have you checked the hub oil? I thought about taking the 4 wheel drive off mine....But it would be to light......and WICKED FAST. I mean too fast...it's already WICKED FAST....thanks to the man RcR.
Old Apr 1, 2004 | 11:13 PM
Default scrammy 4x4
how do you check the hub fluid please dont think im dumb i am just new to this whole atv thing
also do you know anyone that has taken off the 4x4 and did it make a major difference?
Old Apr 1, 2004 | 11:22 PM
ftwflh's Avatar
Default scrammy 4x4
check the fluid in the hub you pull the set screew out and turn it to 4 oclock or 8 oclock and see if fluid runs out.Chances are it is dry and you will need to take it apart and clean it real good.Best bet is to buy a manual it will be the best $$$$$ you will spend and/or save with this machine.
Old Apr 1, 2004 | 11:25 PM
RAJ's Avatar
RAJ
Default scrammy 4x4
They are a allan screw on the out side hub.....turn it to 3 oclock and see if any oil runs out. I don't know anyone that has taken the 4x4 off, but it would make a big difference....one thing it would be lighter.
polaris scrambler00
Jun 20, 2015 08:49 AM
mpcop077
Jun 10, 2015 08:30 PM
MuDsLiCa
Mar 8, 2003 05:50 PM
jett
Dec 11, 2002 09:06 AM
