AC 650 v-twin problems
Old Apr 10, 2004 | 09:24 AM
orky4969's Avatar
Default AC 650 v-twin problems
hi,
has any one had any problems with the AC 650 v-twin?
i have:
1.belt kicked it into limp mode, had to reset it.
2. bought it and the radiator clamp wasnt fully tightened so it was leaking fluids.
3. was about 16 miles from my hous when all the sudden it quit on me --- come to find out the ground in the key switch went bad? how does that work?
4. last night was riding home, when all the sudden, i sunk to the ground, the rear left wheele shaft under the suspension just snapped and broke off, luckily i was somewhat close to home.
good thing there's a 2 year warranty on these things.... i might sell and get another quad.... maybe the polaris 700 ??
what have you had for problems with your AC650??
Old Apr 10, 2004 | 11:43 AM
Cub's Avatar
Cub
I haven't had any problems at all. Only things I have done are adjust the belt, adjust the shocks, and the 100 mile service. It has been nearly perfect! Hope you get all your troubles worked out!
Old Apr 10, 2004 | 09:31 PM
pockets's Avatar
only a limp mode problem with mine has been great otherwise and there is a fix coming for limp mode problem
Old Apr 11, 2004 | 12:51 AM
orky4969's Avatar
every one has this problem so far with limp mode - i'm just going to disconnect the 'censor'
greencat650's Avatar
Yes I have had Mulltiple Problems with mine, If anyone has a lemon mine is, or was. I think I have the bugs worked out now.
Been trouble free for a month now!
Very Pleased with my 650 Monster!!!
Old Apr 11, 2004 | 12:52 AM
orky4969's Avatar
i'm just going to disconnect my limp mode censor.... ---- after how many miles did your's go on? mine was 603
Old Apr 11, 2004 | 12:53 AM
orky4969's Avatar
GREEN CAT 650 --- what problems did you have?
Old Apr 11, 2004 | 01:04 AM
Disconnecting the sensor won't help or fix the problem.
there's a 3 prong white connector on the right rear frame, (remove the side panel to access) I think it's a connector for the
Voltage regulator, anyway you need to clean the terminals and apply some dielectric grease. mine has been fine ever since
I've done this (mabey just a coincidence).
Had the stumbling problem on whoopty doo's. raised the float levels in the carbs, seemed to take care of that!
Old Apr 11, 2004 | 01:22 AM
DanW's Avatar
200 miles, no problems.
Old Apr 11, 2004 | 01:34 AM
Hey DanW you need to start riding that thing I'm Just under 600 miles
