88 250 quad racer...What is the viewing glass for on the motor?
Old Apr 12, 2004 | 11:05 AM
booth's Avatar
Default 88 250 quad racer...What is the viewing glass for on the motor?
On the right side of the motor there is a view hole that you can look and see if there is oil in there or somthing. Origonaly i thought it was for the motor oil but that is not possable as it is above the oil fill and help is greatly appreciated thanx.
post script: it is a 86 or 88 but too early (i am too lazy to look) to confirm unless it is necessary
Old Apr 12, 2004 | 11:40 AM
badchad's Avatar
Well, it is definately not an '85 or '86 - the window you speak off if the sight glass for the powervalve. It's there to ensure that your powervalve is actuating. Your quad is anywhere from an 87 on up.
To make sure your powervalve is opening up, look in the glass while it is running and rev the motor to raise the RPM's. You will see the linkage move up if it is working properly.
Old Apr 12, 2004 | 11:49 AM
booth's Avatar
ok thank you for the info
Old Apr 12, 2004 | 11:53 AM
badchad's Avatar
No problem, glad I could help.
Reactant
Mar 30, 2022 02:08 AM
Frisky2050
Apr 9, 2020 11:19 AM
rcappie4
Jul 10, 2015 04:54 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
