float bowl level?
Old Apr 11, 2004 | 11:29 PM
madhatter801's Avatar
Default float bowl level?
How can I determine the proper float bowl level height?
Old Apr 12, 2004 | 12:15 AM
needaR's Avatar
i was wanting to know that too.how do you adjust it?
madhatter801, i have a kehin PJ carb but i dont know which size it is.would you tell me the number on the side of your carb so i can see if it matches mine?
Old Apr 12, 2004 | 12:19 AM
If you have a stock carb, you have to take off the float bowl, then there is a little metal tab connected to the floats that pushes against the float valve to open or close the valve. You just have to bend that tab up or down to adjust the level.
Old Apr 12, 2004 | 12:22 AM
needaR's Avatar
i have a keihin pj
Old Apr 12, 2004 | 10:23 AM
sorry about that, its basically the same thing on the PJ though
Old Apr 12, 2004 | 12:44 PM
needaR's Avatar
i cant think of anything to measure it.i measured it with a tape measure and it was 24 of the smallest lines.not sure what they are.are they mm?i tired to look at part numbers on the slide and stuff.but i cand find them.what can i use to measure to see what size of a carb i have?
ReconBayou
Oct 31, 2022 05:37 PM
Beeline08
Nov 11, 2016 04:00 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
wrencher82
Sep 24, 2015 03:39 PM
