MX DIET
Old Apr 15, 2004 | 03:36 PM
Blaster2fast's Avatar
Default MX DIET
posted earlier once about weight reduction but i guess i didnt specife for mx because i got replys telling me to remove all plastic drill holes in the frame and yada yda.... is there much i can do for mX? what things can i replace with aluminum? heel guards are off... p-brake and cable and stuff were replaced with aluminum clutch lever ... headlights are gone... any other ideas?
Old Apr 16, 2004 | 12:06 AM
Default MX DIET
BUMP
Old Apr 16, 2004 | 01:24 AM
1BAD250R's Avatar
Default MX DIET
Your on the right track by buying aluminum parts but an important thing is to reduce unsprung weight-basically your entire rear assembly (axle etc). I'd buy aluminum hubs, an aluminum sproket, an aluminum RAD LOC, and carbon fiber wheels if you could afford it.
Old Apr 16, 2004 | 12:48 PM
Default MX DIET
is the eliminator axle lighter than stock? probably not i bet... that rad loc... what eaxcly is that? i dont mind getting that stuff... carbon fiber wheels though our out..
Old Apr 18, 2004 | 03:02 AM
1BAD250R's Avatar
Default MX DIET
Sorry it took me so long to reply. I'm in the middle of rebuilding my 250R so that takes up a lot of my time. I don't have the Durablue Elimianator, I have the X-33 which is more race oriented. It weighs only 11lbs. w/ the aluminum hubs and it has an easily adjustable width that uses a bolt through the hubs instead of messing with those annoying castle nuts and spacers. I would buy it over the eliminator.......it's about $150 more than the Eliminator but worth it if you'll be MX racing. A RAD LOC replaces your stock axle nut that holds your axle into the bearing carrier. Your axle nut is all the way to the right of your brake assembly. All the RAD LOC does is reduce a slight amount of weight but more importantly it stops your axle nut from vibrating loose which happens frequently. It looks like you've already got the aftermarket a-arms and shocks so after this you should be good to go. Nice bike by the way.
Old Apr 19, 2004 | 01:38 PM
Default MX DIET
Thanks!
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
thewayout420
May 7, 2004 02:09 AM
CaptBags
Nov 21, 2003 03:34 PM
Treeshot
Aug 24, 2003 04:55 AM
predator530
Sport Quads
10
Jun 16, 2003 02:54 PM
