Welded crank?
Old Jul 22, 2000 | 08:02 PM
Minkia's Avatar
What exactly is a welded crank?
Old Jul 24, 2000 | 11:45 AM
BenBoal's Avatar
From what I understand, Banshee cranks are pressed on, not splined or keyed(?), and welding the crank will prevent the crank counterweights from moving on the shaft. I will find out whenever I rebuild, and probably have it done by someone who knows what they are doing, because I think they will true it (balance) after welding.
Old Jul 25, 2000 | 11:18 AM
LiveWire's Avatar
The outside journals are just pressed onto a Banshee crank. The Journals can spin on the pins on a modified motor. The crank I had welded by TDR had about 1/4" long welds on it. When the crank needs to be pulled apart again. the welds can be ground out and it can be welded in the same spot again. I do not know whether this is needed as much on singles. With a twin, all the power of both cylinders is passed through the pin of one cylinder.
pgamboa
Dec 24, 2023 11:52 AM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
QuadRiders
Oct 22, 2015 04:13 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Jackg17
Sep 26, 2015 09:30 PM
