high rpm back fire
Old Apr 17, 2004 | 04:03 AM
bansheecop's Avatar
Default high rpm back fire
I have a 98 banshee, runs good till anything over half throttle and then it starts poping back through the right carb. carbs are clean, reeds are good good 140 lbs of compression and new plugs any one have any ideas?
Old Apr 17, 2004 | 10:40 AM
Hozed's Avatar
jetting maybe.
Old Apr 17, 2004 | 10:44 AM
RaptorForever's Avatar
check your exhaust for leaks
Old Apr 17, 2004 | 11:58 AM
Ernie660R's Avatar
Check your reeds and what is your jetting? How many mods have you done to the quad.
Old Apr 18, 2004 | 05:01 AM
bansheecop's Avatar
my jetting was .270 I just put .280 jets in to see if it helped the problem but it didn't. Its been bored .030 has a cool head with 20cc domes boost bottle and stock reeds, FMF Fatty's. I,ve checked the coil , wires stator, flywheel, reeds and Ive even run a bore scope through it. The piston looks good, the bike has run good up till now and its only the right side that pops. It takes off hard and pulls good but as soon as you go past half throttle the power drops off and it starts poping I even checked the float levels and there good??????????
Old Apr 18, 2004 | 02:37 PM
hondabuster's Avatar
Timing advanced too far? If not...has to be lean, either needle or main.
Old Apr 18, 2004 | 03:06 PM
Ernie660R's Avatar
Oh. I all most forgot. Look around the wiring harness on the right side of the frame where you stator plugs into. In that area make sure the wires were not touching the pipe, even if they were not still check for any bare wires. I all most bought a new harness before I checked that. Mine did the same thing yours is doing. Also change the plugs if you have not already.
Old Apr 18, 2004 | 08:37 PM
bansheecop's Avatar
went out to work on it today and the problem was gone. I rode it all day and it ran great so either it's an intermitent problem or it was just a glitch. THe wind here is blowing 60 to 70 mph so maybe it blew the problem away. Thanks for eveyones input.
Old Apr 19, 2004 | 05:53 AM
bansheecop's Avatar
I checked the wiring and its all good also checked the needle and its good
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
robj
Jun 15, 2015 08:45 PM
Steven Bandemer
May 27, 2015 07:39 PM
Mark Vinson
Sep 3, 1999 07:15 AM
