warrior problems
Old Apr 17, 2004 | 12:37 PM
bwiley's Avatar
Default warrior problems
my 97 warrior idles funny, when its in gear it will idle normal, but when its in neutral it idles real high???
what can i do 2 fix this???
Old Apr 17, 2004 | 02:09 PM
bagz's Avatar
check the choke.... make sure the choke is all the way off.... if its not that than idk what it can be
Old Apr 17, 2004 | 03:38 PM
bwiley's Avatar
nah the choke is all the way off...
Old Apr 17, 2004 | 06:25 PM
TrailBlazerguy250's Avatar
Make sure the choke cable isnt sticking
Old Apr 17, 2004 | 08:12 PM
Rider1169's Avatar
could just be ur idle is set high, lower it a little. the reason it might idle normal in gear is because it is very slighty catching and pushing the engine a little, like if u ease out the clutch with no gas. if u adjust ur idle and it idles fine in nuetral, and it stalls alot while u are just sitting in gear with the clutch in, u might have to then also tighent ur clutch cable a little
Old Apr 18, 2004 | 10:57 AM
NLWarrior01's Avatar
There's no choke cable on a Warrior, just a little plunger on the side of the carb .. bit of a nuissance actaully [img]i/expressions/face-icon-small-disgusted.gif[/img]
There could be something sticking on the internals, but still for all, if the bike is idling high in neutral it should continue to do so in gear ...
Does the bike jump when you put it in gear and want to move even at idle? If so, I'd check your clutch cable adjustment .. sounds like it could be out.
Old Apr 18, 2004 | 01:02 PM
OOO thanx for the info Iam buying a 97 Warrior on Monday.
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Reactant
Jul 16, 2015 10:29 PM
