REVERSE LIGHT
Old Apr 17, 2004 | 02:51 PM
pinheadedjoker's Avatar
Default REVERSE LIGHT
My reverse light seems to stay on constantly now.. it didnt happen till i tipped my quad back to remove my engine skit plate.> now it just stays on and kinda flickers the quad runs fine but the light is on what does that mean? any way to reset it or fix it?? thanks
Old Apr 17, 2004 | 02:57 PM
CHEWBACCA's Avatar
well, first thing you should do is check the wires. Did you do that? One could have pulled out or something
Old Apr 17, 2004 | 06:55 PM
yeah i quickly ran over the wires everything seemed fine. it seems as if it flickers according to my revs.. i dont know though and it only happened after i tipped my quad back and ive heard other people talk about this
Old Apr 17, 2004 | 07:37 PM
sixsixT's Avatar
The rev light will flash if you let it sit at a high idle without moving for a few minutes because it's not getting a signal from the speed sensor.
Old Apr 17, 2004 | 07:39 PM
well it sat for about a week and it did it first thing i turned it on.
Old Apr 17, 2004 | 07:46 PM
sixsixT's Avatar
Then that wouldn't be the problem.
Is the rev limiter on like it's in reverse even tho it's not?
Does the light come on went you just turn on the key?
Old Apr 17, 2004 | 07:52 PM
yeah heres what it does the keys off so obviously nothings working but i turn the key on and either it wont be on or it will but it seems dim then i start it it either turns off for a fraction of a second then turns back on or just stays on.. then if i barely rev it it flickers doesnt seem to affect performance and the light comes on and stays solid when its in reverse but im just worried about it. i dont like Red lights. thanks
Old Apr 17, 2004 | 08:37 PM
sixsixT's Avatar
I would try grounding the wire going to the reverse switch, if the light goes out the switch is bad.
If it doesn't go out I would try grounding the same wire where it comes out of the CDI unit. If it goes goes out then you have a bad wire going to the switch.
If it doesn't go out it may be the wire between the bulb and the CDI is rubbing and grounding if not the CDI unit may be the problem and would have it checked or take it to the dealer.
SyTye
Sep 11, 2015 02:45 PM
Pahuntman
Sep 5, 2015 11:07 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
Derek Allen
Jul 22, 2015 09:25 PM
