Clutch engagement
Old Apr 21, 2004 | 02:58 PM
MNScrambler's Avatar
Default Clutch engagement
Does anybody know exactly how many RPM’s different clutch kits will raise the engagement on a Scrambler 500? HPD? Hot Seat? ect…
Old Apr 21, 2004 | 04:46 PM
BigBadScrambler's Avatar
The HPD clutch kit that I have engages @ approx. 2200 RPM (brown primary spring and 58g weights)
Old Apr 21, 2004 | 06:46 PM
ftwflh's Avatar
Best way is to put a spring in and check it with a tach. With a 500 you dont really need the high ngagment to get to the power like you do on a 2stroke.What you DO need it faster shift out to hi gear.That is where your tach will help you.Try you a Polaris green primary with a HPD violet secondary set 2-2.
Old Apr 22, 2004 | 12:34 AM
So does one company's clutch kit have a lower engagement than the others?
Old Apr 22, 2004 | 12:37 AM
They will vary some depending on which primary spring they choose to include
Old Apr 22, 2004 | 07:33 AM
ftwflh's Avatar
Your best bet is to put together a custom kit .Give RcR a call(618-644-3211) and tell Rick what you want out of your machine and he will steer you in the right direction.
Old Apr 22, 2004 | 12:04 PM
Thanks.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
Minimod
Sep 10, 2015 09:20 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
