Clutch engagement
Old 04-21-2004, 02:58 PM
MNScrambler's Avatar
Default Clutch engagement
Does anybody know exactly how many RPM’s different clutch kits will raise the engagement on a Scrambler 500? HPD? Hot Seat? ect…
Old 04-21-2004, 04:46 PM
BigBadScrambler's Avatar
The HPD clutch kit that I have engages @ approx. 2200 RPM (brown primary spring and 58g weights)
Old 04-21-2004, 06:46 PM
ftwflh's Avatar
Best way is to put a spring in and check it with a tach. With a 500 you dont really need the high ngagment to get to the power like you do on a 2stroke.What you DO need it faster shift out to hi gear.That is where your tach will help you.Try you a Polaris green primary with a HPD violet secondary set 2-2.
Old 04-22-2004, 12:34 AM
So does one company's clutch kit have a lower engagement than the others?
Old 04-22-2004, 12:37 AM
They will vary some depending on which primary spring they choose to include
Old 04-22-2004, 07:33 AM
ftwflh's Avatar
Your best bet is to put together a custom kit .Give RcR a call(618-644-3211) and tell Rick what you want out of your machine and he will steer you in the right direction.
Old 04-22-2004, 12:04 PM
Thanks.
buddieboy
12-09-2016 05:50 PM
tysonbully
09-28-2015 02:30 AM
jbrewster94
09-23-2015 04:16 PM
Minimod
09-10-2015 09:20 PM
twon1235
Utility ATVs
09-07-2015 04:38 AM
Quick Reply: Clutch engagement
