need help not runnin right
Old Apr 22, 2004 | 05:48 PM
Snyderman's Avatar
Default need help not runnin right
when my 01 ds gets warm it sputters real bad. it seems like its not getting enough fuel but it does'nt do it untill it gets hot. (not overheating)
Old Apr 22, 2004 | 07:25 PM
Snyderman's Avatar
can annyone help me. got a poker run saterday and i want to show every one what the ds is made of.
Old Apr 22, 2004 | 08:33 PM
BajaIowa's Avatar
I am not very good at diagnosing problems, but the main questions are... Have you adjusted the valves, do you have an aftermarket pipe. is the air filter clean? What jetting have you done so far? I would look back at past posts and there are always a lot of answers to browse.
Justin
Old Apr 22, 2004 | 08:44 PM
amd's Avatar
amd
sounds like it might be flooding when it gets warmed up, you might check your float level and make sure it is not high.
Old Apr 22, 2004 | 09:14 PM
Haulinonthedunes's Avatar
Just to be safe, check ur battery cables. Could be loose which will cause the engine to spit and sputter. Believe me i have seen it happen before.[img]i/expressions/face-icon-small-smile.gif[/img] Lance
Old Apr 24, 2004 | 11:44 AM
marrtoo's Avatar
Is the choke pushed in all the way? did you pull it out 2notches and make sure it went back in 2 notches? is the tank vent tube pinched?
marrtoo
650Mountain
Jun 30, 2003 04:50 PM
KJMAXXX
Jan 14, 2003 08:55 PM
sugarbritches
Oct 16, 2002 03:29 PM
