magura hydraulic clutches
Old Apr 26, 2004 | 10:00 PM
keepitpinned's Avatar
Default magura hydraulic clutches
i own a 04 400ex. im going to be removing the parking brake. instead of just buying another regular clutch lever i was thinking about gettin the hydraulic clutch. does anybody use them how do you like them?
Old May 2, 2004 | 01:38 AM
URCRAZY's Avatar
I am too looking into getting a Magura Hyd. CLutch for my 400. I have one on my TRX 250 and I like it. My buddy his one on his Raptor, it works well. Just that the line gets close to the exhaust and could burn it. If I get this I will be investing in a Stainless Steel line that you can buy for them.
Anyway, does anybody else have them, and how do you like it??
Old May 2, 2004 | 12:56 PM
K_Fulk's Avatar
I like mine ral well. Smooth pull and stays consistant. It also helps make it easier if you have some heavier clutch springs in. And you wont have to replace cables once a year for it to stay pretty easy and you wont ever have to readjust it. The line that comes on it is pretty long so you have plenty of line to stay away from the headpipe. You can switch to a stainless line but its a pain to install one.
I had to lower my mount a lil bit so the slave cylinder wasnt touching my sparks x-6 pipe. But it should be fine for some other pipes.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
