gearcase removal??
I have eveything out of my bike except the gearcase all of the bolts are out of it but its getting hung up on the bolt on the lower left side it's a fairly long bolt going straight in to the side and it wedges the gearcase against the frame there is a nut on the bolt that I have loosened but the bolt itself will not move enough to either clear the frame or come out of the case.
You need to take the bolt that goes all the way through the tranny out and loosen the left side swingarm bolt enough to get the gearcase out.
Yeah that sounds reasonable....I always just took the swing arm out, and replaced the bushings and plastic washers when I was doing it....just so I didn't have to do all of that crap again. I guess that is up to you, I knew you had to take it out the back anyways.
