gearcase removal??
Old Apr 27, 2004 | 12:49 AM
scrambler123's Avatar
Default gearcase removal??
I have eveything out of my bike except the gearcase all of the bolts are out of it but its getting hung up on the bolt on the lower left side it's a fairly long bolt going straight in to the side and it wedges the gearcase against the frame there is a nut on the bolt that I have loosened but the bolt itself will not move enough to either clear the frame or come out of the case.
Old Apr 27, 2004 | 12:52 AM
Bradracer18's Avatar
Boy it has been a long time since I have done it....but I think the gearcase just slides out backwards....
Old Apr 27, 2004 | 01:10 AM
well it could if my swingarm was off but its still on.
Old Apr 27, 2004 | 01:46 AM
He!! I can't remember for sure, so don't take it off, but it I know for a fact that I always took my swing arm out, but you may not have to. Someone in here will tell you for sure.
Old Apr 27, 2004 | 01:48 AM
Thanks Bradracer does anyone else know?
Old Apr 27, 2004 | 07:44 AM
ftwflh's Avatar
You need to take the bolt that goes all the way through the tranny out and loosen the left side swingarm bolt enough to get the gearcase out.
Old Apr 27, 2004 | 11:25 AM
Yeah that sounds reasonable....I always just took the swing arm out, and replaced the bushings and plastic washers when I was doing it....just so I didn't have to do all of that crap again. I guess that is up to you, I knew you had to take it out the back anyways.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
clscott84
Sep 21, 2015 10:16 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
