what do i do with the wire on the parking brake?
Old Apr 27, 2004 | 09:08 PM
kawasaki88man's Avatar
Default what do i do with the wire on the parking brake?
hey i took off the parking back etc. so now i have this problem with the wire going to the engine that cuts it out what should i do with that wire cuz it cuts out my engine help someone
Old Apr 27, 2004 | 09:38 PM
RacerRob's Avatar
Just follow that wire down behind the radiator and you will find that it separates to two wires. Unplug both wires, and you will see one is "male", the other "female". Simply plug those two ends into each other, creating a constant contact which will allow you to remove the "switch" wire that goes to the handlebars....[img]i/expressions/face-icon-small-smile.gif[/img][img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 27, 2004 | 09:56 PM
wshrdskin's Avatar
RacerRob,
Are you sure that you want to connect them? I just cut my wires, before I realized i should have followed them and unplugged them. Anyway, I had to seperate the two wires from any contact or it would cut out.
Old Apr 27, 2004 | 10:24 PM
Hayseed's Avatar
If memory serves me, you unplug one connector and tape it up and the other one you plug the male and female together.
This is for installing a new clutch perch.
Old Apr 27, 2004 | 10:31 PM
wshrdskin's Avatar
That's right, there are two sets of wires going to the clutch perch, one for the parking brake rev limiter and the other for the start the bike in gear mode. I bought a perch that uses the start in any gear connector and I seperated the two wires for the parking brake block off.
Old Apr 27, 2004 | 10:33 PM
so wait lemme get this strait all i do it follow the wire down to where it seprates and just connect them together ?
now i have anything problem my start just makes a noise but not turn over what could be the problem?
Old Apr 28, 2004 | 01:19 AM
RacerRob's Avatar
Thanx guys...I stand corrected[img]i/expressions/face-icon-small-smile.gif[/img] You are right [img]i/expressions/face-icon-small-confused.gif[/img] Its been a couple years since I did it, and my memory has gone to the dogs since then..lol. Too much "soil sampling"...[img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 28, 2004 | 12:31 PM
AlkyBurninX's Avatar
Even better, get a clutch perch/lever from a KLR dirtbike and hook the parking brake wire up to the wire on the new perch. Now you have a holeshot rev limiter!!! RPM's really aren't high enough, but it is worth a try. When the clutch is in it will limit the rpms then let it rev when the clutch is out.
COFatboy
May 2, 2020 12:06 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Tadej Dylan Vuzem
Jul 27, 2015 07:26 AM
DeFox500
Jul 26, 2015 06:32 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
