cam timing
Old Apr 28, 2004 | 06:57 AM
650pete's Avatar
Default cam timing
hey is there any gains to be had by advancing, retarding the cams or one or the other. just a thought that popped into my head while adjusting the valves thanks
Old Apr 28, 2004 | 08:01 AM
saint650's Avatar
Default cam timing
I COULD BE WRONG BUT I DONT THINK YOU CAN ADVANCE ONE TOOTH FOR TWO REASONS. ONE IS IT IS TO MUCH ADVANCE OR RETARD AND I THINK YOU MIGHT RUN IN TO PISTON VALVE CLEARENCE PROBLEMS. NOY 100 PECENT SURE THOUGHT.
Old Apr 28, 2004 | 09:13 AM
Goombadi's Avatar
Default cam timing
instead of messing with the cam timming play around with you ignition timing.
Old Apr 28, 2004 | 10:34 AM
SANDMAN430's Avatar
Default cam timing
yeah i'd look at one of the newer cdi's first vortex or msd. but i have seen a pami have some cam timing done and it made a hugh difference.
Old Apr 28, 2004 | 11:18 AM
ScoobyDFW's Avatar
Default cam timing
i run stock cams with the intake cam retarded one tooth.
Old Apr 28, 2004 | 05:23 PM
SANDMAN430's Avatar
Default cam timing
scooby how many others did you try?
Old Apr 28, 2004 | 05:55 PM
ScoobyDFW's Avatar
Default cam timing
other what? other cam timing with stock cams? other cam grinds?
I retarded the stock intake cam for more upper RPM power and to reduce valve overlap for the turbo. That's all I really tried.
I have a set of web 109's but only had them in for an hour. I had a bunch of unrelated problems surface so I put the stock cams back in, and fixed the problems to get the DS running again, so I didn't get a chance to come to a conclusion on the 109's.
Old Apr 28, 2004 | 08:46 PM
SANDMAN430's Avatar
Default cam timing
yeah i was asking about the cams. i've seen that 760 really change with the cam timing.
Old Apr 28, 2004 | 09:22 PM
TheChosenOne's Avatar
Default cam timing
So for stock cams on a stock quad with a pipe, advancing or retarding the cams is outta the question?
Old Apr 28, 2004 | 11:37 PM
ScoobyDFW's Avatar
Default cam timing
if you're mechanically inclined you can try retarding the intake cam and see if you like it. it will probably have slightly better topend power with maybe a slight reduction in lowend torque. i don't do any work on a dyno so i can't say for sure. i've asked other DS builders about this and they don't respond. i guess it makes sense - why would they spend time dynoing stock cams in retarded/advanced positions, if it works better than stock they are losing business by not selling aftermarket cams.
Sjrpp
May 2, 2023 03:59 PM
slowgsxr97
Mar 18, 2022 03:40 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
