stays full throttle in neutral
Old Apr 29, 2004 | 10:46 AM
jimtob's Avatar
Default stays full throttle in neutral
Hi, I had to take the carb out of my 200s to clean it and when I put it back in and started the bike it sounded like it was in full throttle. I dont want to start it to often to see if its gettin any better because Im afraid Il blow the pistons out of her. Can any on give me a little help on what I should do to fix this problem.
Old Apr 29, 2004 | 11:29 AM
hondarider300's Avatar
make sure the needle is in the right spot and isn't loose or in the wrong spot, also check to make sure all jets are tightend enough to stay in but not over tightend
Old Apr 29, 2004 | 02:15 PM
radfastdude7777777's Avatar
and check your idle screw thing
Old Apr 29, 2004 | 04:46 PM
hondabuster's Avatar
The only way itll rev, is if the slide is staying up. You can have as much gas go in as you want, but it wont rev with out air....the slide is being held open. Either the cable is binding, or the slide was put in backwards, or is hung up on the key in the bore.
Old Apr 29, 2004 | 10:07 PM
yea thats probobly it
Old Apr 29, 2004 | 10:42 PM
ThreeWRacer's Avatar
yea the slides in backwards i did the same thing on my 200
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
blpersinger
Jul 15, 2015 09:56 PM
