oil pressure sensor
Old May 3, 2004 | 09:46 PM
busmechanic's Avatar
Default oil pressure sensor
I think my oil pressure sensor is bad. my dash light is on. if unplugged the light is off. so, i am assuming that the circuit gets grounded when pressure is to low? what pressure sensors and gauges will work in this fitting? if I remove the sensor and crank the engine a little, oil comes out sensor bad. right?
Old May 3, 2004 | 10:24 PM
SANDMAN430's Avatar
temp makes it work also
Old May 3, 2004 | 10:54 PM
couchonwheels's Avatar
Mine did the same thing. I ordered a new one from the dealer, but couldn't wait for it to come in to go riding. I was positive I had oil pressure, so I unplugged it ( just like any other bike that doesn't have a sender). Rode for a while decided to plug it in, and it has worked ever since. Now I have a spare sender in my tool box.
Old May 4, 2004 | 02:11 AM
bench tested the sensor at work tonight. switch opens at aprox. 5psi. and has aprox. 150ohms of resistents with no pressure. seems that may be in spec. wish I knew what factory specs where. I geuss I better check my oil presure with a mechanical gauge. not sure what to think now.
Old May 4, 2004 | 02:56 AM
JMAC650's Avatar
They go out very easy when water gets into them. I have changed mine 4 times on my 04. I always keep 2 or 3 extra's in the tool box.
Old May 4, 2004 | 11:18 AM
TexasPsycho's Avatar
i got tired of mine going out and then i got worried that it might not work if i did lose pressure. i went to auto zone and bought a small gauge set and installed the oil pressure gauge where the tack usually mounts so i can actually see my oil pressure. the gauge comes with 1/8" plastic tubing but i used 1/8 stainless steal tubing insyead so there would be no chance of it rubing or getting a hole melted in it.
Old May 4, 2004 | 07:27 PM
so, just some brake line tube? did you just bend it by hand to where you needed it to be? I found a small gauge that I like. I was thinking maybe some copper tube. now the gears are turning!
Old May 4, 2004 | 09:15 PM
Bahazzzz1's Avatar
I had a mechanical oil pressure gauge, but a gauge failure had me covered in oil doing a trail side repare. I am now using an eletric gauge and it works well. Oil pressure for the DS (qouting manual) 7psi minimum @ idle, 44psi @ 6000rpm, Maximum oil pressure is 87psi. I mounted the gauge in a pod off the dash support bar on the right side of the dash. Works every well, and dosen't move around.
Old May 4, 2004 | 10:52 PM
Indianbullet's Avatar
i too didnt trust the idiot light after having it twig out on me. so i bought a manual guage and mounted it on the right side of my dash and ran the tubing in some rubber vacume line.. i also installed a T so i could still run the idiot light sending unit as well looks and works well
Jeff Roper
Feb 1, 2022 11:48 AM
2many2ride
Sep 27, 2015 04:35 AM
Jeff Roper
Sep 21, 2015 02:11 PM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
