Jetting after putting on new exhaust
Old Dec 26, 1999 | 12:23 AM
Mojave87's Avatar
hey everybody, Merry Christmas,
this year i asked 4 some stuff 4 my quad and i got a White Bros. E series eexahust that came with a air filter spark plug and jets as well as the exhaust. well what i want to know is if i have to re jet it because it is a real pain in the ***. and hard to get to on my Mojave.
Thanks
Ryan
[This message has been edited by atvbbs (edited 12-25-1999).]
Old Dec 26, 1999 | 12:31 AM
exlax250x's Avatar
if you dont re jet it will run like **** with the new pipe
Old Dec 26, 1999 | 02:09 PM
hot_shoe_cv's Avatar
Mojave87,
I can only tell you what a pain it will be to have to replace a burned valve or two due to the engine running lean with the increased air in the mix.
I doubt it would be harder to access you carb than it is on my Warrior. The only consolation is that it does get easier the more you do it .
You didn't say how many discs you'll be running in your silencer or what filter you have, so it's difficult to suggest how much fatter you'll need to go on the main. At the very least you need to go one size fatter on your main from stock, whatever that is.
Your jet needle should be in the nominal position, which is the center slot.
If you want to supply more info on your pipe & filter and need more info on re-jetting, I'm on aol IM & Yahoo!IM or email
THE AZ HARD PACKER, calmiller@kachina.net
save the public land FOR you, not FROM you..join the Blue Ribbon Coalition online @ www.sharetrails.org
Frisky2050
Apr 9, 2020 11:19 AM
toonces
Oct 16, 2019 12:11 PM
coldnorthpol
Jul 14, 2015 11:22 PM
coolguy420
Jul 10, 2015 01:17 AM
bikedad3
Jul 2, 2015 02:15 AM
