wolverine, shifts alot harder than it used to
Old May 10, 2004 | 01:00 PM
bmwm5ive's Avatar
Default wolverine, shifts alot harder than it used to
i always feel like im droppin rocks the transmission whenever i shift gears. especially downshifting.
i never beat up on the thing so i dont know why its doin it. if i remember right, it used to shift alot
easier and smoother. is there any way i can make
shifting a little easier on the machine??? i turned the free play screw a bit but it hasnt helped much. someone help.
Old May 10, 2004 | 02:42 PM
Lomax's Avatar
Have you tried adjusting the linkage between the shifter and the shift shaft?
Old May 11, 2004 | 11:01 PM
shastadog's Avatar
You can adjust your clutch on the left side to add a little more clutch. The early Wolvys used to have a problem with the clutch springs, not at all hard to change out. This may have happened to yours, those clutch spings can break. If adjusting it doesn't help...I would pull the cover and look at my springs.
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
95wolv
Sep 27, 2024 12:00 PM
kbazzy
Sep 26, 2015 11:26 AM
Clint Russell
Sep 25, 2015 03:20 PM
BigCam
Sep 16, 2015 01:53 AM
