Warrior-Rod,piston crank also oil pump.
Old May 10, 2004 | 11:12 PM
2000IAWarrior's Avatar
Default Warrior-Rod,piston crank also oil pump.
well as some of you knew i threw a bearing on my crank/rod i was told that you can not but a new rod and have it installed that you have to get a new crank becauz it could not be torn apart and a new rod put in and put back together. is this ture? and do any of you know were i can get a good rod/pistion kit and possibly a new crank?
also means there was lots of metal shavings i was told the oil pump is probly about Junk so were is the cheapest place to get an oil pump..
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Jackg17
Sep 26, 2015 09:30 PM
BYC
Sep 25, 2015 02:10 PM
Sw00p
Sep 24, 2015 02:50 PM
