warrior smoking
Old May 11, 2004 | 10:21 PM
Vipers619's Avatar
Default warrior smoking
my 88 warrior smokes a little when you hit the high rpm's.i will just rev it up alot and you will see smoke come out. can this be from too much oil in the motor?do i need new piston rings, i don't think i do. the quad won't smoke when riding, just when you rev it up or when you are pinned in 6th gear flying on a road.does anyone have any info.thanx
Old May 12, 2004 | 12:21 AM
superwarrior's Avatar
I have an 03 and I changed the jets in it and when I run cheap gas it does the same thing. What Kind of gas do you run. Is the smoke black. I had the same prob. but as soon as I changed the gas it ran fine.
Old May 12, 2004 | 05:00 PM
Vipers619's Avatar
i run 87 octane?
Old May 12, 2004 | 05:08 PM
Heapster's Avatar
Do a compression test to tell if your rings are tired..........warriors are pretty bullet proof, but yeah check your oil level. Most likely, any "burning oil" is from tired valve guides, and not worn rings?
Being a 1988, it's a tired motor all around. Has it led a rough life and has it ever been torn down before?
Old May 12, 2004 | 09:09 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
hey that does that on my friends 88 warrior... does yours come out from under the seat?
Old May 15, 2004 | 05:33 PM
did you try running a higher octane
Old May 15, 2004 | 09:07 PM
Vipers619's Avatar
i haven't tried a higher octane. i have an hmf pipe on it and a k@n air filter with a modified air box. i took out the spark plug and it has carbon all over it.i am guessing that this means it is running to rich.i checked my main jet and it is145, the stock jetting, so i don't know why it smoked that little bit at the high rpms?anymore help would be helpful!
Old May 15, 2004 | 09:17 PM
Lomax's Avatar
If its a grayish-blue smoke then your prolly need new valve guides or rings. If its a black smoke then its likley to be in the jetting ( although it would be odd that it would be rich having mods with stock jetting ) or caurberation.
Old May 16, 2004 | 10:54 PM
Vipers619's Avatar
i really don't think the little smoking really matters that much but i am getting a compression check to see what is going on in the motor.
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
EIF
Apr 20, 2017 07:15 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
