removing piston???
Old May 16, 2004 | 09:19 PM
tbsleeper's Avatar
Default removing piston???
hey i was trying to get the piston off today but i couldnt!! i tried to remove the c clip thing but couldnt and then i tried to push out the pin, but i couldnt. so could someone tell me how to. thanks!!
Old May 16, 2004 | 11:17 PM
mudmaster250's Avatar
well u cant get the pin out without the c-clips out, to take those out just get a small flathead screw driver in there and pry them out. but becuase to stick a rag down in your bottom end cuz u dont need to be fishing a c-clip out of there.
Old May 17, 2004 | 12:19 AM
quadwrench's Avatar
There is a small indention in the piston's "hole" that the piston pin goes through - this indention will let you get a small screw driver (I use an ice pick) under the "c" clip to lift it up while prying outwards. Depending on the condition of the piston and pin, after you get the "c" clip out, you may have to exert a little force to get the piston pin to move through to release the pin from the connecting rod.
Like mud said - stuff a shop rag or towel into the crankcase hole under the piston to keep the flying "c" clip and other debris from falling into the engine.
Old May 17, 2004 | 12:02 PM
1998trailblazingfool's Avatar
Well, if hitting it and it still don't budge, take a c clamp and a bolt to fit the piston pin. Than just crank. Once you get to far, the pin will hit the c=clamp, so than try to position the cclamp above the piston pin. Thats how i got my piston off since i melted the piston(jetting being off)
Old May 17, 2004 | 07:53 PM
BigNig's Avatar
hey mudmaster....how much was it too hook up your quad?? with all the mods i mean, and do u live in az?
Old May 18, 2004 | 12:07 AM
BayouBlaster's Avatar
Ok, just my $.02 for what it's worth. After I got the c-clips out, I used a socket from one of my socket sets to punch it out. I had one that fit it just perfectly. If you want to help hold the piston steady while you're doing this, just get you a piece of 1X4 about 6" long and split it down the middle and put the 2 pieces on top of the crankcase and push the piston down until it rests on the boards. Then it won't move too much while you punch it out no matter which method you decide to use. Good luck!
Old May 18, 2004 | 06:21 PM
about 350 for the dirtdevils, kenda klaws, grips and lights, then 300 for the porting, bore, piston, head milling, and then 325 for the stage one, 55 for the chain tensioner i just ordered, 40 for the two clutch springs i just ordered, 35 for the chain i just ordered, 16 for the 12 tooth front sprocket i just ordered, 22 for the 38 tooth rear sprocket i just ordered. i also have a rear rack but i dont know how much that was.
Old May 18, 2004 | 11:10 PM
EAB's Avatar
EAB
http://www.startinglineproducts.com/Polaris_Catalog/pinpuller.html (for info, I dont expect yuo to buy it)
Old May 19, 2004 | 12:13 AM
scrambler123's Avatar
wow! AZ bad Boys does the motor work pretty cheap.
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
atvcollector
Sep 8, 2015 05:11 PM
Jason Richards
Sep 4, 2015 06:17 PM
