sp 700 not charging .... help
Old May 17, 2004 | 12:00 PM
jroffroad's Avatar
Default sp 700 not charging .... help
my fathers 03 sp700 is not charging. the batt. light flashed a while, when he stopped and tried to start it later it wouldn't. when he got home he checked and it was not charging. he does not ride through water or aggressive. just went spring gobbler hunting and was upset when he got back.
Old May 17, 2004 | 02:17 PM
Polaridoo's Avatar
Check the negative terminal on the battery. Possibly could have gotten a defective battery. Possibly bad stator. How do you know its not charging? Did you check it with a meter?
Old May 17, 2004 | 03:28 PM
jroffroad's Avatar
yes he checked it with a meter
Old May 17, 2004 | 03:38 PM
Polaridoo's Avatar
What all has he checked? Is the battery OK - or will it even accept a charge? Has he looked for a bad connection somewhere?
Old May 17, 2004 | 03:41 PM
jroffroad's Avatar
yes he checked to see if it was charging before and after he charged the batt. with a charger, the batt. is fine
Old May 17, 2004 | 03:47 PM
Polaridoo's Avatar
Well, if everything looks ok, and there is NO charge from the stator, then you are probably talking about the stator or regulator.
Old May 17, 2004 | 05:19 PM
Snowride's Avatar
The connector for the voltage reg is up by the radiator under the hood, kind of a pita to get at but my guess is the harness plug is disconnected. Give it a look.
Old May 20, 2004 | 03:54 PM
jroffroad's Avatar
checked the relay/breakers under the hood [good]. could someone post the charging wiring diagram, or tell me where i can test the stator? thanks
Old May 20, 2004 | 04:18 PM
Polaridoo's Avatar
I have that at home and will try to post that tonight if I can get some free time. I think you pretty much have shown it to be the stator though. If you are not getting a charge from the positive battery terminal to the battery then you either have a wire disconnected somewhere or a bumb stator. If you checked for any loose wires or bad connections and know that the voltage regulator is working ok, then it probably will need a new stator. As soon as I get a chance, I will post the details.
ReconBayou
Oct 31, 2022 05:37 PM
speedbuff
13
Nov 11, 2020 10:16 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Jersey General
1) Engine problems..
Sep 13, 2015 01:05 PM
zPuls3
Sep 12, 2015 08:54 AM
