CAN'T MAKE IT IDLE
Old May 18, 2004 | 01:29 PM
EDDIEHASKELL's Avatar
Default CAN'T MAKE IT IDLE
I HAVE A 87 250R IT HAS NEW STATOR, CDI, 38mm PWK CARB I HAVE REPLACED A LOT ON THE QUAD IT HAS A FMF FATTY PIPE NEW VFORCE REEDS. I HAVE TO ADJUST THE IDLE SCREW ON THE CARB ALL THE WAY IN FOR IT TO PARTIALLY IDLE BEFORE IT BOGS OUT THE CARB WAS JETTED FOR A TRX250 (SUPPOSEDLY) WHEN I BOUGHT IT. ANY CLUES I NEED HELP?[img]i/expressions/face-icon-small-confused.gif[/img]
Old May 18, 2004 | 01:35 PM
Shav0's Avatar
I would try adjusting your jetting, The air mixture screw, as well as the pilot are both responsiable for idleing.
Old May 18, 2004 | 06:03 PM
bansheeesmoker's Avatar
First of all you need to adjust the air screw out to make it idle faster. Where is your needle clip at? And what is the main jet and pilot jet?
Old May 18, 2004 | 07:14 PM
powerslider's Avatar
Smaller pilot jet will do the trick, worked for me on mine..
Old May 18, 2004 | 08:53 PM
dragracer789's Avatar
Acually your wrong, no biggie thow... On the PWK38mm carbs when you turn it in it will make it rev up more because it moves the slid UP. Next time you have a 38PWK apart take a look at it and you will see...I dont mean to be mean, but I was just correcting you....
Anyways play with your pilot jet and air screw some.
Old May 18, 2004 | 09:08 PM
Actually he's right, the airscrew is different than the idle adjustment screw. Backing the airscrew out will allow more air in but if the pilot jet is too large it still won't be enough to idle right so lean the pilot out.....
Old May 18, 2004 | 09:12 PM
OOPS my bad I though they meant the idle screw. I read to fast sometimes.
Old May 18, 2004 | 09:26 PM
LOL I have to read some of this stuff twice to make sure I got it right, no biggy.....
Old May 19, 2004 | 06:52 PM
I thought you had me there. Yea start with the pilot if that dosent work try adjustingthe needle clip down one slot.
Cole Hadden
Jun 15, 2025 09:05 AM
Firefighter400
Oct 8, 2022 06:38 PM
clsharky
Jul 13, 2015 02:07 PM
ranvette
Jul 12, 2015 06:34 AM
MNatv89
Jul 7, 2015 11:36 AM
