CAN'T MAKE IT IDLE
I HAVE A 87 250R IT HAS NEW STATOR, CDI, 38mm PWK CARB I HAVE REPLACED A LOT ON THE QUAD IT HAS A FMF FATTY PIPE NEW VFORCE REEDS. I HAVE TO ADJUST THE IDLE SCREW ON THE CARB ALL THE WAY IN FOR IT TO PARTIALLY IDLE BEFORE IT BOGS OUT THE CARB WAS JETTED FOR A TRX250 (SUPPOSEDLY) WHEN I BOUGHT IT. ANY CLUES I NEED HELP?[img]i/expressions/face-icon-small-confused.gif[/img]
First of all you need to adjust the air screw out to make it idle faster. Where is your needle clip at? And what is the main jet and pilot jet?
Anyways play with your pilot jet and air screw some.
Actually he's right, the airscrew is different than the idle adjustment screw. Backing the airscrew out will allow more air in but if the pilot jet is too large it still won't be enough to idle right so lean the pilot out.....
ranvette
Jul 12, 2015 06:34 AM
