Grizzly Spark Plug Problem
Old May 18, 2004 | 09:18 PM
RedGoblin's Avatar
Default Grizzly Spark Plug Problem
When two friends and I were riding last weekend, we got into some seat-deep water. My friend's 660 Grizzly all of a sudden started sputtering and then died. Couldn't get it started again so we towed it back home and checked it out in the garage. Spark plug cap had come off of it. We pushed that sucker back on there good and tight and went back out. Same results. We plan to do some creek riding at my place in a couple weeks. How can we keep the cap on the spark plug without it popping off again while riding in the water? Would just holding it down and then taping it down tightly with electrical tape or something work? My other friend has a 450 Kodiak and this has never happened to him.
Old May 18, 2004 | 10:22 PM
suzukiltz's Avatar
Try gettin a bigger end plug that little thing that screws on the top of the plug if not that work try a new spark plug how old is your grizz???
Old May 18, 2004 | 11:02 PM
RedGoblin's Avatar
My buddy's grizz is an '03 with just over 900 miles on it. By the way, for future reference, I mean the end of the plug opposite that of the end that goes into the actual cylinder. It's the end with the cap that snaps onto the top of the plug that runs from the ignition coil.
Old May 19, 2004 | 05:31 PM
RedGoblin's Avatar
Come on, none of the gearheads on here have any solutions?
Old May 19, 2004 | 05:53 PM
Doctorturbo's Avatar
GOT BOOST!
If it's a rubber boot then get some pliers and give the boot a "gentle" squeeze. This will oblong the barrel that locks onto the plug. You should get a nice snap on the plug when you do this.
Old May 19, 2004 | 10:33 PM
suzukiltz's Avatar
Well i dont know much about yamahas.. but they are the same as almost any quad!! when docturbo said a gental sqeeze make sure you dont over bend! let us know how it turns out!! a 03 shouldnt have too many probs its only a year old!! thats why suzuki is more reliable and honda for working around the farm
Old May 20, 2004 | 10:42 AM
Andy Bassham's Avatar
Make sure the little thread things aren't stripped out on the part that goes over the plug. If I'm right, its a ribbed plastic piece, and its kind of threaded to hold itself down in the hole. You can feel it when you push it down onto the plug, cause it vibrates as the ribs go down in there. If those things are stripped, then there probably isn't anything to keep it from just sliding out. That piece is hard plastic rather than rubber. Where as a rubber boot would be tight around the plug itself and hold itself on, the 660 spark plug connector is hard plastic and the threading on the outer sides of it grips to the engine casing itself rather than to the plug. Might need to replace the plastic plug boot.
njrider64
Jul 4, 2017 01:40 AM
WilliamBos
Sep 30, 2015 08:08 AM
Ty Speece
Jul 2, 2015 04:59 PM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
Ask the Editor
Jun 3, 2015 04:16 PM
