400ex cam timing PLEASE HELP
Old May 21, 2004 | 03:40 PM
00400ex's Avatar
Default 400ex cam timing PLEASE HELP
Can someone explain how i should cam my time. I know people are going to say buy a service manual ( i did but it didn't come yet) can someone please help on how to time. AIM = Eitner8 Please help
Old May 22, 2004 | 04:16 AM
420EX's Avatar
Unbolt your cam sprocket from the cam and remove the bolts then unscrew the timing hole cover on your left engine side cover and line up the T on the flywheel with the little line on the cover, you have to look closely with a flashlight but it's there. Next, turn the cam so the lobes are facing down, look at the sprocket and make sure you have the outside of it facing out and you will see three marks, one on each side across from each other and one at the top middle, line up the middle lines that are across from each other parallel with your head (the one on the engine, lol) make sure you have the cam chain on the sproclet while your doing this and you have the chain tensioner off with the cam chain completly stretched out. It's hard to explain but I hope I got my point accross.
Old May 22, 2004 | 11:30 PM
00400ex's Avatar
yes u did thanks alot.. i got it running but its making alotta of chattering noise what could this b the vavle train? should i make it tighter? what should i do
Old May 24, 2004 | 02:35 PM
cals400ex's Avatar
you need to make sure that timing is correct for one. also, make sure your valves are adjusted properly according to the cam you run.
Old May 24, 2004 | 05:48 PM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
did you put the chain tensioner back in?
Reactant
Mar 30, 2022 02:08 AM
slowgsxr97
Mar 18, 2022 03:40 AM
95wolv
Jul 21, 2015 12:25 PM
95wolv
Jul 17, 2015 08:13 PM
yambam13
Jul 4, 2015 01:49 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
