700 Front Diff won't disengage
Old May 21, 2004 | 06:26 PM
T56's Avatar
T56
Default 700 Front Diff won't disengage
2002 700. For some reason my AWD switch won't release the front drive line. Any suggestions?
Note: This machine sees lots of deep water. I'm already planning on replacing the gear oil all around as my dealer suggested.
Old May 21, 2004 | 06:29 PM
BigBadScrambler's Avatar
I would also suggest changing the gear oil as well. Since the hillard clutch is in the front gearcase. Dirty and/or contaminated oil could be causing that
Oh, and welcome to the forums!!
Old May 21, 2004 | 06:32 PM
T56's Avatar
T56
Lets hope thats what it is. I've had so much trouble with this machine already that an easy fix would be nice.
Old May 22, 2004 | 10:16 AM
Randrball's Avatar
your problem most likely is the armature plate that was redesigned in 2004. it's not a hard fix so remove the front diff and replace the old designed armature plate with the new design. $60 and problem solved!!!!
Old May 22, 2004 | 10:42 AM
Bubs's Avatar
my brother inlaw was a 04.5 500 and ever since he got it new it would engage into 4x4 by itself when the rear wheels were spinning,he took it back to dealer and they replaced everything in the front drive , its better but it still does it,hes not a happy camper.So as far as the new ones being better i dont see how.Im glad i pick the 04 500 instead,like my dealer suggested ,thats saying somthing right there.I think they should of stuck with what works.
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 5, 2015 05:55 PM
Sportsman850
Jul 31, 2015 04:25 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
