A few banshee questions
Old Aug 1, 2000 | 02:00 PM
rottwolf's Avatar
Hello all. I got two questions right now. First: I notice when I first started it(after sitting a day) it will smoke either out of the tip of the head, or the connection where the pipe and the silencer meet( I have a motofast 2-1 pipe). What is this?
Second: I need a repair manual..Clymer has nothing newer than a 94..I have a 96..what should I do?
Thanks,
Jason
Old Aug 1, 2000 | 02:22 PM
BANMAN's Avatar
I just bought a clymer for my 98 banshee. I ordered it through Amazon.com. It was easy and fast! As for the smoke ?????????????? head gasket???????????? just a guess. GOOD LUCK!
Old Aug 1, 2000 | 05:31 PM
BansheeBrad's Avatar
All the banshees are the same.. at least the 1990 and up are all the same.
87-89 had J arms instead of A arms and different stock gearing..
The clymer manual will have everything you need, the only spec I could never find is flywheel to pick up distance. (I guessed at it and still don't know.)
Just my $.02
Brad
Old Aug 1, 2000 | 10:32 PM
HILLSVILLE69's Avatar
I thought 90s had J arms also? and then 91 started the new a arm.s
Old Aug 2, 2000 | 12:36 AM
rottwolf's Avatar
Hey dude, how did you order the clymer for your specific year model? I don't see it asking that? It just says 87-99? Did I miss something? I want to order one too.
Thanks,
jason
Old Aug 2, 2000 | 01:46 PM
409LongRod's Avatar
did you read the last post or not rott? ALL BANSHEES ARE THE SAME!! That is why it says 87-99 the only change that was made was the j-arm/a-arm thing in 89 i think.
Old Aug 2, 2000 | 05:48 PM
sAyIt_fmf's Avatar
there is one more thing that was changed...Go down to your dealer and order a (stock)rear sprocket for an 89 banshee...then order one for a 96.....
different number of teeth.....
I argued with my dealer for a half an hour about that..... I was under the impression that the only thing that changed was the arms.... I guess I was wrong...or they are wrong. But the Microfiche for each model year shows different "stock" tooth counts on the sprockets.
Old Aug 2, 2000 | 06:51 PM
RoostKing's Avatar
I am also under the impression that the ealry banshees were slightly case ported. Is this true? They stopped because they wanted to slow it down some, that what I heard anyhow...
RoostKing...
Old Aug 2, 2000 | 10:30 PM
Man666son's Avatar
ok i'm gettin a 1990 banshee sunday(im trading for my 300eX) and i thought it has j-arms....... and im almost positive they put a-arms on them in '91 and is the case different, if it is what kind of difference does it make?
Old Aug 3, 2000 | 11:17 AM
87-90 were J arms... 91 and up are A arms
The gearing changed as well.. went from a 13 front to a 14.. and dropped a tooth or 2 in the rear. (I think)
ALSO.. the rear hub size is different. it has a different bolt pattern on the early banshee. Don't know the model year it changed, but it might have been from the 90 to the 91s.
