Exhaust options
Old May 24, 2004 | 11:46 PM
Bahazzzz1's Avatar
Default Exhaust options
Well my mbrp broke in half this weekend after I went through a puddle. The stock exhaust will be going back on for now. Has anybody cut the flame arrester off the stock end cap for additional noise and power, and if so how much? Will you get comparable results to an aftermarket end cap?
Old May 25, 2004 | 12:20 AM
rldbobcat's Avatar
here is what i did to my original endcap and like the results so far
http://forums.atvconnection.com/mess...did/400988.cfm
Old May 25, 2004 | 12:31 AM
lilnotts's Avatar
uhhh could u explain this a bit more?
Old May 25, 2004 | 09:58 AM
BajaIowa's Avatar
Mr. HP endcap all the way. He has the best support for correct jetting, and it is the highest performing exhaust except for one or two full systems. His website is Mr. HP
Justin
Old May 25, 2004 | 07:43 PM
Bahazzzz1's Avatar
Well what happined to my mbrp is, at the beggining of my ride I went through a bit of water. I guess the water hitting the exhaust caused it to break apart from the rapid cool down. The pipe broke just infront of the weld infront of the silencer. It was new in augest. Check yours for cracks.
Old May 25, 2004 | 07:47 PM
650VIPER's Avatar
Yes you can cut it. cut it right in front of the flange that goes around the silencer. remove everything but the two external tubes. It wont perform as good as an aftermarket, but it makes a big difference over stock.
mrtidy
Feb 3, 2016 05:00 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
black_thunder
Sep 22, 2015 07:59 PM
