CARB TALK
Old Aug 2, 2000 | 12:55 AM
TheLaw's Avatar
well guys, i called carbparts.com and they have a mikuni 34mm, maybe a 32mm TM pumper for $250 with adapters, and i called Racers Edge Racing and they have a Lectron 36mm RAce carb.. what do you guys think of going to a bigger carb, any downsides?
Old Aug 2, 2000 | 03:04 AM
Tree Farmer's Avatar
My opinion only, The Law; unless you modify your engine extensively (e.g., bored & stroked, cammed, piped, maybe ported-and-polished), you're not likely to gain anything from a larger carb. In fact, over-carbureting can diminish performance, especially at lower rpm's.
A different type carburetor (e.g., slide vs. CV), such as some of those you mention, can give different throttle response characteristics, but these features would only be justified expense-wise in my opinion by someone in serious racing competion. For a stock bore-and-stroke utility ATV, the OEM carbs, properly jetted, do a pretty good all-around job.
If you're serious about hopping up your Honda 300, Gordon Banks obtained outstanding results on his with a Powroll bore-and-stroke kit.
Tree Farmer
Old Aug 2, 2000 | 03:08 AM
TheLaw's Avatar
I have looked into a 400 Bore from Thumper Racing which is a reasonaable price. but id rather jsut have bolt on power, and yes i do have an aggressive cam,pipe,plug,filter,etc,etc...im looking for max power out of the bike to turn my tires....
Old Aug 2, 2000 | 08:36 AM
Right; missed the cam (fell asleep in the middle of that long signature, actually (hehehehehe)).
You could use a couple of millimeters of increased carb bore diameter, I think; but--nothing like the zero to redline gain a Powroll or similar displacement boost would give (the increase on Gordon's Fourtrax is modest; to around 330 cc or something like that, but the performance jump is phenomenal).
Carburetor Parts Warehouse is a good outfit to deal with, if you go the carburetor transplant route; sounds like your ATV is very "sanitary" with all the right stuff; good luck!
Tree Farmer
Old Aug 2, 2000 | 06:16 PM
supertraprecon's Avatar
i still think the lectron would really only be worth it unless its on a pretty hoped up race motor..... i think for YOUR quad the mikuni would be best
Old Aug 2, 2000 | 09:31 PM
frankd's Avatar
i would jet the 32mm out,a bigger carb will help your top end but i think its gonna choke your engine when you bog it down in mud,keep in mind most 500s run a 34mm
Old Aug 4, 2000 | 02:41 AM
TheLaw's Avatar
well guys, today was the day.
i decided i would call both and whicchever seemed more promising, i would order from.
i called carbparts first, and they had a 32mm TM, 33mm TM with accelerator, and a 36mm TM with accelerator. the accelerators were too expensive($400 range), so i narrowed it down to 32mm TM($250).
i then called racers edge racing.
they sell mikuni also, but rather the lectrons.
they have a 34mm and a 36mm High Velocity. i told the salesman my mods, and he said i can go to the 36mm without a problem.
the lectrons were about 270.
so, upon hearing that and the polices, i oped for the Lectron 36mm on the spot. it will be here tuesday at latest, will let everyone know how it goes!
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Captjay
Jul 23, 2015 12:33 PM
Aitch
Jul 21, 2015 09:40 PM
