How much difference does a pipe make?
Old Aug 2, 2000 | 12:24 PM
250rampage's Avatar
I have a Honda Recon, and the only pipes I can find are a DG, and a supertrapp IDS. How much difference these pipes make from stock.
Old Aug 2, 2000 | 12:29 PM
FoxRunner's Avatar
Depending on your type of bike a pipe can make the difference between night and day. So far in your selection though take this much advice DG stands for "Dont Go" or "Dont Get" take your pick. SuperTrapp is pretty darn good though.
Old Aug 2, 2000 | 08:13 PM
trapperb1's Avatar
I've had a 250SX Honda, 200X Honda, 350X Honda. I've had Supertrapps on ALL of them, along with K&N airfilters. Tremendous difference from stock. The thing I like about Supertrapps is that they are so easily tuned by adding/subtracting discs from the muffler. They are definitely worth the money. You may need to adapt a heat guard for your leg if you replace the header pipe.
Old Aug 2, 2000 | 08:50 PM
250rampage's Avatar
Thanks for the advice, I will buy a Supertrapp IDS 2 within a few months. I don't have to worry about a heat shield, the IDS 2 for the recon is a slip on model, and nobody makes a aftermarket head pipe for it. I have also heard that if you take the screw off that you use to purge the exhaust it will help performance. HAs anyone else ever heard of this?
Old Aug 2, 2000 | 09:53 PM
250Thumper's Avatar
the supertrapp isnt a slip on. you pay somewhere around 229.99 and you get an s-bend pipe, a u shaped pipe, and a silencer.
Old Aug 3, 2000 | 02:36 PM
supertraprecon's Avatar
nope its an s bend full headpipe one not a slip on i took the drain plug outa my stock exhaust it did help performance but it ran LEAN thats NOT good i ordered a 5 pack of jets from dennis kirk and am gonna try to make it run right with the drain plug removed tell yea how it goes
lightninboy
May 16, 2021 09:52 PM
1966F100
Jul 14, 2015 12:19 PM
cSchwartz
Jul 12, 2015 07:42 PM
rcappie4
Jul 10, 2015 04:54 PM
cornermike
Jul 8, 2015 11:44 PM
