sportsman 500 question??
Old May 31, 2004 | 05:01 PM
DSWOLF's Avatar
Default sportsman 500 question??
is it hard to do a oil change on this quad,what kind of oil should i use,is there an oil filter and how much oil do i put in it.
thanks for any help you guys can give me.
Old May 31, 2004 | 08:43 PM
xcrider's Avatar
What year sportsman? There is a drain plug on the tank and the filter you can get at Polais, NAPA or use a WIX(Napa # 1358, Wix 51358). I prefer the NAPA or WIX Filters. You need to use 0w40 wt synthetic that you can get at Polaris or use the AMS Oil 0w40. You need 2 quarts. The is a plug that holds about a cup that is under the right side of the engine, almost behind the foot brake and it is a bugger to get out. It can be done but if your not that mechanical then forget that one, it is only a cup of oil. Now if you sank it in water then get busy. Your supposed to take out the screen in the tank clean and then reprime the oil pump. I wouldn't do this all the time but once in awhile just to see what is in the screen. I think it takes 2 quarts emptying the extra cup.
Old May 31, 2004 | 08:56 PM
BigBadScrambler's Avatar
To add to xcrider's post. The Napa Gold filter is made by Wix. That is what I use. In addition to the Amsoil 0W-40, you can also run Mobil 1 0W-40 synthetic "European car formula". The screen I wouldn't worry to much about. I did mine once and it was clean. But, I would definately do the crankcase. It isnt that hard to get at if you drop the skid plate.
Old Jun 1, 2004 | 11:53 PM
DSWOLF's Avatar
thanks guys by the way it's a 03.
Old Jun 2, 2004 | 01:09 PM
yaK's Avatar
yaK
just to add to bbs's post...you shouldnt have to remove the skid plate to drain the crank....I can reach mine easy on my 400
Old Jun 2, 2004 | 01:28 PM
Whitewater's Avatar
I just changed the oil on both my 400 and 500. It was quite easy. I looked around for the cheapest option (i.e., Wal-Mart, etc.), cause I'm a cheap *** and Polaris gets you coming and going. However to my astonishment, I ended up going to my local Polaris dealer and bought an oil change kit - it was actually about the same price as Wal-Mart, except it contained a screw on funnel, 2-gaskets, and instructions.
Cole Hadden
Jun 15, 2025 09:05 AM
1966F100
Jul 12, 2015 03:08 AM
tporath
Jul 11, 2015 12:31 PM
toonces
Jul 11, 2015 12:01 PM
200es
Jul 10, 2015 09:09 AM
