Anybody have a Warrior miss at high speed??
Old May 31, 2004 | 10:19 PM
HMFIC's Avatar
Default Anybody have a Warrior miss at high speed??
I think I need to adjust the valves but I just wanted to see if anybody else has had this problem before I yank the gas tank. The carb is in perfect shape and it is bone stock.
Old Jun 1, 2004 | 01:01 AM
RaptorOwner's Avatar
How about the rev limiter? If your tacking that motor out it will hit the rev limiter. Or your jetting needs to be adjusted.
Old Jun 1, 2004 | 02:26 AM
Wolverine350R's Avatar
I have read before that the ground on the reverse, i believe, can cause this kind of problem, might try to do a search on it.
Old Jun 1, 2004 | 08:41 PM
4wheelsc's Avatar
he's definitely right it's either rev limitwer or jetting if you check your plug it could be the jetting but if you tack it all the way out all warriors do it
Old Jun 1, 2004 | 08:47 PM
HMFIC's Avatar
Thanks guys. I really appreciate the help.
Reactant
Mar 30, 2022 02:08 AM
Nondem
Feb 22, 2020 12:20 PM
manuelrivera
Aug 8, 2015 04:34 PM
black_thunder
Jul 28, 2015 11:05 PM
bpegram84
Jul 22, 2015 08:15 AM
