carb boots?
Old Jun 1, 2004 | 01:05 AM
braveops's Avatar
Default carb boots?
if i go to a 38 mill carb where can i get a boot to fit my 400?
Old Jun 7, 2004 | 08:40 AM
braveops's Avatar
Default carb boots?
hmmm no one has ever put a bigger carb on there bike? if i go with a 38,39 mill carb where can i get rubber boot from?
Old Jun 7, 2004 | 12:01 PM
CED's Avatar
CED
Default carb boots?
The stock boot will work it is just a tight fit.
Old Jun 7, 2004 | 12:57 PM
braveops's Avatar
Default carb boots?
thanx my stock boot is tight now i thought you would have to replace it
okay now if i go with the 39mil what needle ,slide and pilot, and main jet should i go with? on my stock carb i run a 220 main and everything else is stock on the carb but i might bore the stock one out in the mean time
Old Jun 7, 2004 | 01:27 PM
CED's Avatar
CED
Default carb boots?
Well if you don't have the 39 PWK yet i would highly suggest that you get it from either Rick Ritter or HPD,they set them up different.When i had the 39 i was running a 35 pilot,EEG needle and around a 178 main.This was with a race mod but this should still get you in the ballpark.
Old Jun 7, 2004 | 01:35 PM
braveops's Avatar
Default carb boots?
THANX i have a buddy that has some that he said he would get rid of 1 for me as for the hpd race i am going to get a trail port and the flywheel done here pretty quick i just need some where to start with the carb
Old Jun 12, 2004 | 03:06 PM
braveops's Avatar
Default carb boots?
okay i got my 39pwk what slide should be in it ? the one in there now is a #6 and the needle is r1368 g? they had a 160main but i will pick up some bigger ones
GregM
Mar 6, 2018 06:53 AM
TLC
3) General Discussions..
8
Jul 26, 2015 11:09 AM
TLC
Jul 25, 2015 02:24 AM
Aitch
Jul 21, 2015 09:40 PM
tporath
Jul 11, 2015 12:31 PM
