The dial-a-jet!!!!
Old Jun 2, 2004 | 01:46 AM
badazzpred's Avatar
Default The dial-a-jet!!!!
Is anyone currently running the dial-a-jet On there machine? If so what kind of machine Is It? And Is It worth the investment?
Thanks...............
Old Jun 2, 2004 | 07:29 PM
scramblered's Avatar
i do run one for severals now on my 2 stroke 400,,i use the dually type one,,the main goal is to gain fine jetting while the dial-a-jet is at
middle hole setting,,,then you can lean or richen as much both side,,,
and it work better that way,,,it do pre-atomize the fuel for a smoother
fuel delivrery and better respoonse as well.
you can gain some ponies on depending on some conditions/altitude and temp.it do work and worth the money but it worth to spend the time and fine tuning to get most of it tough...
on a thumper i don't known if it worth so i can't tell.
Old Jun 2, 2004 | 08:02 PM
speeeedy's Avatar
very well said
[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jun 2, 2004 | 11:17 PM
badazzpred's Avatar
How much does It cost In the end? I can buy the kit from rocky mountain for $65.00 does this not Include everything? And sorry but I did not quite understand your post scramblered./............................................
Old Jun 3, 2004 | 09:48 AM
i would simply say,don't mess with it on a 4 stroke,,,or i just can't tell how it work on a thumper but as far i'm concerned on a scrammy,
it did run very good when dialed-in properly.
Old Jun 3, 2004 | 11:21 AM
Hairback357's Avatar
I have a buddy with one on a Sportsman 700 and he swears up and down it is the best thing since sliced bread.
Old Jun 3, 2004 | 03:52 PM
so,it sound it is because i didn't get any testing done on a 4 stroke polaris with it so far i can't tell,but i swear it can make the same result on it if you properly tune it,it work!
Old Jun 3, 2004 | 04:33 PM
psychotic400ex's Avatar
I have Dial-A-Jet on my 400ex, as of right now, I hate the stupid thing. Unless you plan on Jetting your carb when you get it, it will make your machine way too rich. I don't suggest it. I regret spending the $75.00 for it.
Old Jun 3, 2004 | 07:34 PM
badazzpred's Avatar
I talked with ben over at rath racing he says with my mods and my elevation to run a 50 pilot jet, drop one clip on the needle, and run either a 172.5 to a 175 main jet I should be good to go. Thanks ben and rath racing, you guys dont hesitate to help someone out. Thanks again............................................. ........Slim
So as for the dial-a-jet I will pass but thanks guys for the input and help on my post.................
STLyamwar
Jul 25, 2020 04:44 AM
jnisson
Jun 14, 2004 07:21 PM
joequad
May 15, 2004 01:39 PM
Vforcer
Aug 8, 2003 01:41 AM
Oxygen
Feb 24, 2003 09:14 PM
