bogging tb`
Old Jun 3, 2004 | 12:11 AM
TWEEKER's Avatar
Default bogging tb`
when i first get it running it's awsome for about 3 minutes throttle response is great then when it warms up it has a dead spot on the bottom not bad just enough to pi@@ you off kinda like a damb knat is it lean or to rich i saw that some one said to run a 210 main that seems awlfully big need some answers thanks
Old Jun 3, 2004 | 07:48 AM
ftwflh's Avatar
Default bogging tb`
This may sound stupid but have you cleaned your air filter lately?
Old Jun 3, 2004 | 11:25 AM
Hairback357's Avatar
Default bogging tb`
I had that problem with a TB before and what it turned out to be for me was a crack in the oil injecter line. Replaced the line to the oil injecter and it fixed it.
Old Jun 3, 2004 | 04:44 PM
tbsleeper's Avatar
Default bogging tb`
for some odd reason when im either going slow or goin down a hill, when i let off the throttle the engine basically shuts itself off. but like ftw said clean ur damn filter then check back in
Old Jun 3, 2004 | 10:36 PM
niceman's Avatar
Default bogging tb`
i know exactly what he means. when mine is run for about 20mins it loses power. and then when i shut it off let it sit for about 10mins it has way more response. i think this has to do with the engine being a piston port engine but i could be wrong.
hueby
Nov 6, 2015 11:34 AM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
essonlaker
Sep 10, 2015 01:12 PM
spark1051
Utility ATVs
Sep 4, 2015 07:58 PM
