HELp broke my rear hub & sprocket 2001 raptor
I broke the sprocket and part of the hub off, I need to replace it but I can't figure out how to get the hub off.
Is there a special tool that I need or am I just a Sped and can't figure it out?
It comes off from the brake rotor side. You have to pull the axle. I have one on my old axle I was going to throw on ebay, pm me and make me an offer for it.......
Start by taking off the right rear wheel hub. Take off the two big (2") nuts off the brake side of the axle. Then using a socket over the end of the axle so you don't damage the threads, tap it out. It will come out to the left. Then you can take the sprocket hub off and replace it. Then put back together by reversing the order. This is how the 2002 works. I believe the '01 is the same?
RR1
RR1
thanks raptorowner that makes sense now. I will try it this weekend. If I get it off I will contact you to see if you still have the hub and sprocket. thanks agian
Originally posted by: pusboil
Just tap it off? this after I remove the axle from the brake side? I saw the bolts on the brake side...
Are the bolt/nut things you are seeing the carrier bolts? Kind of a flat oval bolt head on the sprocket side, and a 17mm? nut on the brake side?
If so, you don't have to remove those.
RR1
RR1
