AC 650 auto, bypass to run with blown ign fuse
Old Jun 6, 2004 | 11:49 AM
snowbuzzard's Avatar
Default AC 650 auto, bypass to run with bown ign fuse
The scenario;
Riding in a very remote area, go through a small draw, the quad quits, no dash, no power to start, winch does not work. Lights work, fan works. Of course, the ignition fuse is blown. I replace the fuse, turn on the key, and snap, out goes the fuse again. I know the older cats would start with the rope when this happens, but not with the 650. Has cat built in a way to do this with the 650? or do I have to rig up some type of short to the coil. Let me tell you, I was not happy being towed out of there for the second time in 4 rides on the new quad.
Why did the fuse blow? I have no idea, but it's sitting at the dealer now, I'll keep you posted.
Old Jun 6, 2004 | 12:59 PM
kwc's Avatar
kwc
Default AC 650 auto, bypass to run with blown ign fuse
Mine did the same thing the first day I rode it. The brake light wire from the brake lever was routed between the handlebars and the clamps instead of around them. After a few hours the bars/clamps rubbed through the insulation and it grounded out and blew the ignition fuse. Check all your wires.
Joe454
Nov 20, 2020 01:19 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Lucas Bohanan
Sep 29, 2015 01:16 AM
Clint Russell
Sep 25, 2015 03:20 PM
