New YFZ...Idle Problems
Old Jun 8, 2004 | 02:08 AM
Mrmonk's Avatar
Default New YFZ...Idle Problems
Quick question. Just got a YFZ 2 days ago and am having some idle problems. When you go fast then pull in the clutch to coast and begin to slow down it dies. Is this a simple turn the idle screw fix or is this something more? My brother called me and told me about the problem, I won't have the bike back till tomorrow. Also, he said after about 20 minutes of riding it gets better. Thanks yall.
Old Jun 8, 2004 | 03:03 AM
yzbluebeast631's Avatar
I've seen this problem a couple times at the shop I work at. First, start the quad and let it warm up. Make sure the clutch is adjusted properly(at the perch there should be 3 to 5 mm of cable slack)
It more than likely just needs to be idled up a bit. There is a black **** to the rear of the carb on the left side. Turn it clockwise.
Old Jun 8, 2004 | 04:48 AM
Mrmonk's Avatar
Thanks alot for the tip, i'll check it out when I get it back tomorrow. Thanks.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
