Clutch weights?
Old Aug 4, 2000 | 12:46 PM
Jaime's Avatar
Ok here goes if you put taller tires on and lost top end rpm , should you not be able to put lighter weights in the primary clutch to gain back the lost rpm on top or would you use heaver wieghts?
Old Aug 4, 2000 | 01:36 PM
bayougrizz's Avatar
i don't know about the polaris tranny, but if it uses the same basic principles as the yamaha ultramatic, you would use lighter weights to INCREASE rpm at any given speed.
Old Aug 4, 2000 | 03:52 PM
truck's Avatar
Heavy weights give you better take off but you
loose top end,lighter weights should give back
your top end loss.
GOOD LUCK
TRUCK
buddieboy
Dec 9, 2016 05:50 PM
Robinhood
Dec 26, 2015 10:28 AM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
