to lift or not to lift
Old Jun 8, 2004 | 09:38 PM
supertech's Avatar
Default to lift or not to lift
i have an 03 650 prairie which i would like to lift and put on some 28s.i have doubts about it now because of the stories about axles popping out and cvs breaking in deep mud.is it a good ideal to lift or see if the 28s will fit without it.thanks for the help.
Old Jun 9, 2004 | 11:58 AM
newbeatle's Avatar
IMO, you are correct, to question a lift... there are several used ones for sale, look on most of the ATV forums for sale areas, & they are there... 1" - 2" is the maximum lift, & yes there are axel CV problem associated with a lift... if you are doing only mudding, & never put your quad, in a situation, where the suspension is either fully compressed, or fully extended, under power, you may be OK with one... otherwise, I wouldn't...
yes most 28" tires will go right on a Prairie with out problems... a tire with large sidewall lugs ( like an Outlaw), may require wheel spacers or wider off set rims, to run a 12" wide rear , with out rubbing the gas tank shield...
Old Jun 10, 2004 | 02:25 AM
Glenlivet's Avatar
Even 4x4 trucks experience u-joint problems when lifted, and a lift on a truck with relatively long driveshafts only increases the angle a few degrees. Consider what change of angle a super short quad driveshaft undergoes when the machine is lifted. The manufacturer designs the joints to work to a certain angle (or rather, designs the suspension to stop travel at the point the CV joint should not accommodate further angle load) If the quad could have reliably operated that degree higher, there is no reason the manufacturer wouldn't have built it that way, to better compete in the marketplace.
That could be an awfully expensive inch or two. But I expressed this opinion once before and had somebody who sells lift kits (!) rail on about how he's never heard of one breaking a CV joint. There ya go.
Old Jun 10, 2004 | 11:32 PM
willride4gas's Avatar
Asked a Honda mechanic about em a couple days ago. Quote "I don't recommend them". All I know about it. [img]i/expressions/face-icon-small-sad.gif[/img]
Old Jun 11, 2004 | 09:19 PM
whereisthemud's Avatar
I put on a lift and love it.
Old May 12, 2005 | 07:40 PM
katman's Avatar
so would i........new beatle.......you know the power!
...........this is a goood topic,,,a glen....?....
british columbia,,,, wow i love the inter net.....
thats far away, but beautiful land ,hats off to ta,.[img]i/expressions/face-icon-small-happy.gif[/img]
QuadRiders
Oct 22, 2015 04:13 PM
Cantbuytime
Aug 17, 2015 06:33 PM
Cantbuytime
Aug 16, 2015 09:13 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
