Sparks
Old Jun 10, 2004 | 01:19 PM
400sEXridr's Avatar
Default Sparks
I do mostly woods and trail riding, but some tracks every now and then. Should I get the Sparks x4 or x6? I plan on doing some minor motor mods later. Is there anywhere else to get a spark arrestor for either of the pipes? Paying $60 more just for the spark arrestor seems like a load of bulls***.
Old Jun 10, 2004 | 01:52 PM
cals400ex's Avatar
Default Sparks
my buddies x-4 performs better than my x-6 and we both have 406 engines. however, mine is stainless and his is ceramic so that will definately help his out. i think the x-6 headers are just too big.
Old Jun 10, 2004 | 08:10 PM
400sEXridr's Avatar
Default Sparks
how much more low end power does the x4 have than the x6?
Old Jun 11, 2004 | 05:01 AM
cals400ex's Avatar
Default Sparks
actually this sounds weird but he beats me worse up top than down low. the power comes on sooner down low. it isn't all that much. however, it starts screaming when he hits 4th. it just seems like my pipe is too dang big in the upper gears. i am not sure.
Old Jun 11, 2004 | 11:14 AM
400sEXridr's Avatar
Default Sparks
which pipes are u talking about? Does he have any other mods done to his bike? I heard the x6 works alot better with motor mods
Old Jun 11, 2004 | 03:30 PM
SpeedDemon13's Avatar
Default Sparks
i have the same problem, i just got a brand new 2003 400ex and i am going to put jets, k&n and exhaust but i dont know which sparks to get? I want more top speed and more torque, i only go about 60 maybe and all my friends willl beat me, and i want to be able to pop wheelies ezier cause i cant pop wheelies ez at all
Old Jun 12, 2004 | 04:59 AM
cals400ex's Avatar
Default Sparks
yes, sparks says the x-6 works better on a motor with any internals in it. however, i am wondering if that is not the case. the x-6 definately won't have the torque the x-4 has. believe me, the x-4 will gain good top end power too. i know they say mainly for low end but i would say you notice more top speed than low end with the x-4. here are my friends and my setups:
mine: x-6 stainless steel, stage 2 hotcam, 10.8:1 406 ross, filter, jets
friends: x-4 ceramic, stage 1 hotcam, 10:1 406 wiseco, filter, jets
our jetting is very similar so i know that isn't an issue.
speeddemon, here is what you need to do. look where the throttle cable goes into the housing on the handlebars. pull back that black rubber piece. adjust that nut and bolt so that you only have about 1/4 inch of slack in the throttle lever. don't go much tighter or the throttle will be too tight but don't go much looser or you will loose power. what happens is that these throttle levers are loose from the factory and the carb isn't opening up fully when you floor it. this will help out big time if it isn't adjusted properly.
Old Jun 12, 2004 | 01:34 PM
redwings's Avatar
Default Sparks
I have an x6 with a 39mm card and my 400 hauls azz I also do alot of woods riding as well as track Forgot to mention If you get the x6 make sure you zip tie your rear brake line as close to your frame as your can get it because I melted mine I'm sure the x4 is the same
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
