Help! MY shocks are bottoming out too easy.(lt250r)
Old Aug 4, 2000 | 11:16 PM
iwana400ex's Avatar
I already adjusted the springs,and i dont want them to tight,i also want low speed plushness but when i go off jumps the bottom out to easy.I think they need recharged or revalved i dont know ,I have Ohlins shocks in the front and stock in back maybe i need need to adjust something else,but what?
1991 lt250r lots o mods
Old Aug 7, 2000 | 02:20 AM
zootue's Avatar
Do you have compression adjustment (an adjustment on the rez if you have rez's)? This is what you adjust to soak up landings. The spring, or springs, is/are for preload (Ride hieght). If you are too low you will bottom, use more spring tension. If your shocks are around 12 to 18 months old with alot of hours on them then you may need a rebuild. Are you landing on the down side of the jumps? If not, then landing flat or on the face of jumps may be your problem. Another question is, are your shock set up for you? Did you buy the shocks from someone else? Later.....
Old Aug 7, 2000 | 03:00 AM
iwana400ex's Avatar
Is the compression adjustment a screw or bolt(on the res.)? if so what way do i turn it? I bought the quad used so i dont know how many hours are on the shocks.the front are ohlins but look pretty old and the back shock spring is almost tightend all the way but still bottoms out.and for the jumps i do a lot of 4-5' high jumps with no landings but thats not the only times they bottom out.They also bottom on jumps with landings.
Old Aug 9, 2000 | 09:44 PM
zootue's Avatar
The comp. adjustment on my rez is a flat head screw. Screw the **** or screw in for more comp and out for less comp. Your spring adjustment is almost maxed out and you are still bottoming out. It sounds like you need a rebuild $$$$$$.
badgerboy1
Sep 26, 2017 06:11 PM
Beeline08
Nov 11, 2016 04:00 PM
2many2ride
Sep 27, 2015 04:35 AM
Levi Enstad
Sep 26, 2015 08:00 AM
cboler9
Sep 24, 2015 08:35 PM
