predator oil tank?
Old Jun 12, 2004 | 12:26 PM
theTICK's Avatar
Default predator oil tank?
I was wondering who has put in an aftermarket oil tank? I would like to but not sure which one is the best?
I think with the more oil holding in it and the aluminum would be better cooling the oil before running back into the motor.
Any help would be great!
Mike
Old Jun 12, 2004 | 01:03 PM
Bradracer18's Avatar
I think CFM has one.....check thier site.....I think modquad has one.....CFM
Old Jun 12, 2004 | 04:43 PM
modquad's Avatar
Yup. Great quality, and top notch customer service. Just make sure to idle the machine a bit before checking your oil level. There is some drain-back. Helps keep things cooler also. Too bad you're soooo far away, I'd offer to polish it for you. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 1, 2004 | 03:47 AM
Predatorizer's Avatar
I brought the cfm oil tank. Put it wouldn't fit with my exhaust so I had to install and notch in it to clear the pipe. Ask Neil be order if it work's with your exhaust. Only costed me $40.00 to have the step welded in!!!
Old Aug 1, 2004 | 01:43 PM
theTICK's Avatar
What type of pie do you have? I had to loosen the front motor mounts to fitt the tank bye the stock header.
Old Aug 2, 2004 | 02:48 AM
With hpd head pipe, the lower pipe sits in the middle of the oil tank at the top right. Down about 1 1/2 inches. Inwards about 1 3/4 of an inches. So notching and place for the head pipe is needed and installing them as a assembly was required. cfm racing said they angled the complete right side to clearance the hpd pipe, but needed have the head pipe to work with like I did. That my piece of pie.
Old Aug 2, 2004 | 02:20 PM
theTICK's Avatar
Did you lose any oil capacity?
With the header pipe so close do you think it would heat up the tank?
Old Aug 3, 2004 | 01:21 AM
No! because it's right the top of the tank I put a pic. with my photo so you can see what I did! Love the tank looks cool.
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
wrencher82
Sep 24, 2015 03:39 PM
