New more top end for my scrambler...
Ok I want to bump up a tooth on the front sprocket for some top end but who makes a good sprocket? Thanks for any replies and if you have any other tips to get some more top end post them. Thanks again...
Keith
Keith
You dont want to mess around with the gear ratios on the 4wd scramblers. You can really start to mess some stuff up it you were to put it in 4wd with the rear ratio changed from the factory setting. You can set your secondary spring to 1-1 for a little more top end, but will sacrifice some acceleration. Try lightening it up some. Otherwise, you are going to want to start going into the motor for more power
