do i need to buy a special wrench to adjust predator 500 front shocks?
from factory my7 front shocks were set quite compressed and stiff, i want to soften them up a bit but dont have any wrench to turn the lock nuts.
please help.....thanks
You can use a brass punch and a hammer to adjust the shocks. By using a brass punch you won't damage the lock rings and it is much cheaper than buying a shock wrench.
thanks a lot, i think i'll be usin the brass punch method at that price.
Harbor Freight Tools has a 4 piece spanner wrench set for only $15.99........thats FOUR wrenches of different sizes to do your shock preload, for only $16......
check out their website for item number 41243.
If you keep the threads clean and hit them with contact cleaner after your rides the only one you should need a punch for is the top lock nut. You "should" be able to turn the lower and upper lock rings by hand once you've removed the intial torque.
toonces
Oct 16, 2019 12:11 PM
Zorro
8
Jan 24, 2001 01:18 AM
