Replacing Swingarm need help......
Old Jun 17, 2004 | 02:39 PM
BigRedDS650's Avatar
Default Replacing Swingarm need help......
I have a 2004 DS650 Baja X, getting ready to order a new ace fabrication +4 swingarm. Need to know besides new chain and new brake line what other parts do I need to purchase for the replacement. Not sure what I'm doing any advice would be appreciated. Thanks
Old Jun 17, 2004 | 02:41 PM
SANDMAN430's Avatar
probably need a 130 link chain
Old Jun 17, 2004 | 06:37 PM
JDsBusa's Avatar
If it is going to be the old style(00-03) you will also need a caliper bracket from the old style, lower shock shims, lower shock bolt.
I just ordered all the stuff to do the same from 222.
Justin
Old Jun 18, 2004 | 01:03 AM
jbracer's Avatar
You'll probably need new bushings for the front of the swingarm. They are very hard to get out without trashing them.
Old Jun 18, 2004 | 01:11 AM
BigWaynester's Avatar
I thought it was a 120 link chain?
Old Jun 18, 2004 | 01:54 AM
DuneMe's Avatar
Don't even try to re-use them.
Pivot Works should have the kits. I would think Rocky Mt. ATV would have it.
You may need a new brake line too.
Since you ar epulling the axel you may as well replace the bearing carrier bearings.
Old Jun 18, 2004 | 11:01 AM
BillDS650's Avatar
No brass bushing on the 04 and 05 the new swing arm uses bearings and different pivot bolt
Old Jun 18, 2004 | 11:05 AM
Can I reuse the bearings or should they be replaced? How will the shock react to the +4 on the swingarm?
Old Jun 18, 2004 | 11:17 AM
TBD's Avatar
TBD
Removing the bearings without damaging them would be very difficult. New ones are highly recomended.
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 5, 2015 05:55 PM
toonces
Jul 28, 2015 01:58 PM
95wolv
Jul 21, 2015 12:25 PM
trouttracker
Jul 20, 2015 11:54 AM
